Go Back   RC-Monster Forums > Support Forums > Team Tekin
Anyone know if you remove the switch( RX 8) if it voids your warantee
Anyone know if you remove the switch( RX 8) if it voids your warantee - 06.30.2009, 06:35 PM
Just wondering...I usually wire the leads together due to the fact that they fail eventually anyway
Yes
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Yes - 06.30.2009, 07:10 PM
If you physically remove anything from a product they will more than likely not honor any warrenty. From a legal standpoint that is their leverage in a law suite stating that you removed or changed their product from its original state from the factory, therefor causing the units ultimate failure. So yes it will invalidate the warrenty.
SUPERMAXX YOUR LIFE.
littlejohn
07.08.2009, 12:12 AM
Can't really comment on what the official line from Tekin is, but CC says you can do pretty much what ever you want with the switch so long as you don't solder anything directly onto the PCB..
TekinTeamMgr
TekinTeamMgr's Avatar
07.12.2009, 01:30 PM
We don't reccomend it however it shouldn't cause a warranty issue unless your mod causes it to fail.
  Send a message via Yahoo to TekinTeamMgr
