Can i make a e-revo transmission fit on a nitro revo chassis?
Hockeyplaya20
Hockeyplaya20's Avatar
Can i make a e-revo transmission fit on a nitro revo chassis? - 07.22.2009, 02:06 PM
Yes, i know that the holes are off, because they are 2 different transmissions. So i figured, ill cut a big piece of metal and screw it on. Then i would measure how much i would need to cut. And cut a big square in the middle of the transmission. Then drill new holes. If this did work, would anything else be a problem fitting?
6s MMM E-Revo l Rustler VXL l Stampede XL-5
brushlessboy16
brushlessboy16's Avatar
07.22.2009, 02:10 PM
you might want to reword what your saying... cuz i have no idea what your talking about
Hockeyplaya20
07.22.2009, 02:11 PM
ok, fixed the title :)
Hockeyplaya20
07.22.2009, 05:44 PM
wow, im dumb... i figured ill go and try to make this mount in 1 shot deal. i cut the alum and everything. To find out it doesn't fit. i just realized i should have used some clear plastic as a template...
07.22.2009, 05:47 PM
I did it to my 3.3 Revo and put the 3905 trans. in...simple to do....and yes a template is a must!
Hockeyplaya20
07.22.2009, 06:03 PM
thanks, trying to figure out where to put stuff now, esc where old engine mount was, battery on side (make a holder), and rx in the middle (im mounting the motor in the front making a gap in the middle.)
Would you happen to have any pics?
Hockeyplaya20
07.22.2009, 09:31 PM
After making a template i finally got a outline!! :)
The holes match up perfect!!!!
So next step, cut along inside line to make hole for tranny to get in
side 1
side 2
