Need Extensive help...
Brushless Moose
Unhappy Need Extensive help... - 07.25.2009, 02:38 AM
Ok, first of all, this will be a long a$$ post. Second, if all you are going to say is "buy a MMM" then don't bother.
--My Setup--
E Revo
Novak HV pro 5.5
Spektrum DX3 (old model) and glitch buster cap
2s lipos in series. (4s)
--My Issue--
With everything hooked up, as soon as I blip the throttle, power will be cut to the Rx for 2-3sec. If I extremely smoothly apply throttle ever so gingerly, it doesn't happen. But, any sudden throttle input will cause me to lose Rx power.
To remedy this, I added a Rx battery pack plugged into the batt port on the spektrum rx. This has solved the glitch issue, but has created an even worse issue. The LVC no longer functions. it allows the lipos to drop to fatal levels without even notifying me in any way (yes LVC is turned ON). As soon as I unplug the Rx pack, bam, LVC kicks in.
--My Pleading--
If anyone has any Idea how to solve either of the issues, PLEASE chime in. I know it is not cutting out because of weak packs, because I am running 6500mah 30C lipos.
