UBEC needed on 14 cells?
Alex Berman
UBEC needed on 14 cells? - 02.19.2006, 11:27 PM
Hey guys,
I've been running 14 cells on my 9918/9L with the Mod1 Set Up - should I be running UBEC? I saw somewhere that if you have more than 12 it is nescessary..
Alex
boss 302
02.19.2006, 11:47 PM
i have heard a lot of guys say that you should run a UBEC on anything over 12 cells but i also remember hearing somewhere that it can handle up to 14 cells without a UBEC. In short i would like to know the real answer.
MetalMan
MetalMan's Avatar
02.20.2006, 12:19 AM
While it may not have burned out (yet), it would not hurt to use a UBEC. I've read that the max. you should use is 12 cells, and this has to do with the heat that the regulator chip has to dissiapate (more voltage = more heat).
boss 302
02.20.2006, 12:20 AM
thanks metalman
MaxxFusion
MaxxFusion's Avatar
02.20.2006, 09:25 AM
I have a 9918/9L and have a UBEC. I run get one for sure.
  Send a message via MSN to MaxxFusion
coolhandcountry
coolhandcountry's Avatar
02.20.2006, 11:00 AM
I have tried the bec in a bk on 16 cells before. It works for a little while. If you run only one servo it will last longer to. I think the ubec is the way to go. Seemed to make the truck run better when put it on there.
