Mamba Moster Max BEC and maxi servo
gyn77
Mamba Moster Max BEC and maxi servo - 10.27.2009, 09:15 AM
I would use this maxi servo on Mamba Monster Max with its internal BEC.
http://www3.towerhobbies.com/cgi-bin...?&I=LXN610&P=7
Theese are the specs of the servo:
8mA idle and 800mA at zero-load operation
Speed: 0.20 sec. at 60° w/ 8.4V battery.
Output Torque: 16.0 kg-cm (224 oz-in) at 4.8V.
Can I use it without problems or do I need an external BEC?
How many Mah can handle the mamba monster max BEC?
whitrzac
Can't catch this...
whitrzac's Avatar
10.27.2009, 02:07 PM
IDK but that is a slow @$$ sevo... its probably .30-.40 at 6v
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
10.27.2009, 04:34 PM
yeah...very very slow!!!
you'll need a very long arm in it to speed up the steering response.
10.27.2009, 07:09 PM
Q. What vehicle was this servo going to be used in?
gyn77
10.28.2009, 04:12 AM
I would use it in this homemade vehicle:
http://www.rc-monster.com/forum/showthread.php?t=23285
I know that this servo is very slow, but my ask was if mamba monster max can
handle this servo without external BEC.
Now I'm using a Tower Pro MG995, I think this hitec maxi servo could work better.
10.28.2009, 02:50 PM
I believe the BEC in the MMM is rated for either 3 or 5amps @ ~6v, so it should be fine. That said, I would go with a better servo regardless- hobbycity sell a ton of really nice items with similar torque ratings & metal gears, worth having a look around before settling on that hitec monster.
gyn77
10.29.2009, 06:15 AM
Ok thanks for mamba monster bec specs, I will see on hobbycity for a faster maxi servo with metal gears instead of this Hitec.
