What systems are you running?
aznnboiy
What systems are you running? - 11.16.2009, 11:06 PM
Well i have a revo 3.3 and planning on converting but dont know what system to go with.Post up what you're running.
Thanks
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
11.17.2009, 04:33 AM
i run a MMM 2200kv combo with an e-maxx 3905 tranny.
you will need better diffs
also...the tekin RX8 also looks promising...but i'm a castle fanboy and love their customer service..even to international customers!!
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
11.17.2009, 07:21 AM
Well, i don't have a conversion, but here is my setup
castle nue 2200kv
quark 125b
DOH, should have said just read my sig.....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
11.17.2009, 07:47 AM
mmm esc on all of my conversions:
1. mbx-5T mmm w/castleneu 2200kv
2. mbx-5 mmm w/1512
Erevocanuck
11.17.2009, 07:50 AM
I`m running MMM 2200kv combo in my E-revo with two SMC 9000 2S batteries.
phildogg
phildogg's Avatar
11.17.2009, 08:11 AM
I run a mmm/2200 in a E-revo.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
brushlessboy16
brushlessboy16's Avatar
11.17.2009, 09:02 AM
MMM 2200 in a revo conversion.
Semi Pro
Semi Pro's Avatar
11.17.2009, 05:27 PM
i was running the castle hv110 with a neu 1515 2.5d but i wanted alittle more top end so i changed the motor to the CC2200 in my revo platinum conversion
on 5cell lipo
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.17.2009, 08:03 PM
I run the MMM combo that came with my E-Revo Brushless Edition. Well not really, the original MMM is in a box ever since I ran it with two 5S lipos accidentally plugged in series. It still runs fine but I was told that I might have blown the TVS device in it so I ordered a new MMM combo and that's what I run now.
No brain, no headaches.
aznnboiy
11.18.2009, 12:48 AM
i think i might go with the 2200kv system and has anybody tryed to put a losi 8ight-t 2.0 body on a revo 3.3?
shaunjohnson
i pwn nitro
11.18.2009, 06:08 AM
someone at my local track has a 8-T2 body on a revo...but it looks bad
aznnboiy
11.18.2009, 08:10 PM
oh well how fast does your revo go with the 2200kv system
Semi Pro
Semi Pro's Avatar
11.18.2009, 09:03 PM
35-40mph .......... depends on how bad the tekno clutch is slipping
aznnboiy
11.18.2009, 09:26 PM
thats sit?i thought it would be like 50mph like the erevo brushless
Semi Pro
Semi Pro's Avatar
11.19.2009, 12:07 AM
it all depends on the gear ratios and what motor mount you get
with the tekno mount you have to use a clutch so you will be limited to a max gearing of 17/36
i have close ratio gears in mine (i track race, not bash)
i run 5 cell lipo
with revo responce tires (5.1 in tall)
you end up with a top speed of 41mph.............but, the clutch will slip,the slipper will slip,your batteries wont hold 18.5v under load and many other things factor into lowering your top speed and you end up running alittle over 35mph
a revo conversion can be pushed to almost 100mph with the castle 2200 motor,6cell lipo, e-revo transmission and foam tires............. just depends on what you $ want to spend
