Brushless conversion from 23cc gas engine.
Mozzy
Mozzy's Avatar
Brushless conversion from 23cc gas engine. - 01.20.2010, 10:56 AM
Hey guy's, long time no see, huh?
Anyway, I'm trying to piece together some details on my conversion.
I want to power a Navicraft Outrage offshore hull with a brushless motor on 10-12s.
http://www.navicraftboats.com/html/N...t_outrage.html
The boat currently houses a 23-26cc gas engine & I want something that will put out more power that this on twin 5-6s packs in series.
I would like to have at least 15,000-20,000rpm from the motor.
Any ideas on what to get & where from?
Cheers Moz.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
01.20.2010, 11:23 AM
You need a big motor, like the 2230 neu. And a big esc that can handle 10-12s lipo, like the castle hv boat esc. And some really big batteries, I would go with the zippy 40c 5000mah 6s packs, get 4 of them, so you can run a 12s2p setup. That way you can run 2 sets of 2 packs in series, and parallel them for a full 10000mah 12s lipo. Boats can draw some juice, so you need alot of battery! So there is 1500bucks worth of stuff to buy!
Mozzy
Mozzy's Avatar
01.20.2010, 11:37 AM
Cool, thanks.
Good starting point.
Decided that this is more like the hull I want.
http://www.fastelectrics.com/hulls/masocat1-6.jpg
Powered by a Neu 2230/1.5Y 485kv with a Hydra 240HV running on 12s2p.
Should tip the scales a scrape under 7kgs.
Any input or other ideas??
