Other uses for Lipo and how to Protect them
sikeston34m
sikeston34m's Avatar
Other uses for Lipo and how to Protect them - 02.06.2010, 07:04 PM
Hi Guys,
I've been playing around with ideas on making different things rechargeable.
Lithium Ion, being the GREAT source of power that it is, is ideal for this IMO.
It only has one short coming. The cells MUST be protected and safeguarded against overdischarge.
Any Lipo cell has it's limit on just how low you can discharge it before irreversible damage occurs.
This protection is accomplised in Cell phone, PDA, Laptop, Digital Camera Batteries and many others, by using a Protective Circtuit Board.
The PCB must match the number of cells that you plan on using in a series.
Alot of PCB's have different specs, so you must match the PCB to the cells in use.
A PCB has a Low Voltage Cutout built into it. The LVC turns off the power when any of the cells in the pack reach a preset lower limit.
The one I'm using cuts power when cell voltage just bumps 3.0 volts per cell. This is ideal for Lipo, so is well suited.
Let's look at a few pictures and you'll get a better idea of what's going on.
First picture shows an overview:
I have attached a PCB that I robbed from an old PDA battery that used 3 Lithium Ion Prismatic cells in series.
I'm also using a cell balancer to monitor individual cell voltage. This is a good accurate way to see what the PCB is doing with the pack, since I didn't have actual specs for this PCB.
I'm also using a watt meter to track how many amps our load is.
A Mamba Max Pro is powering a Prop attached to a brushless motor. (Makes for one heck of a fan too...........LOL)
I'm using a servo tester for speed control on the ESC.
Here's a closeup of the PCB. I have attached to a printed circuit board, 4 female JST balance connectors. This will allow me to attach up to 4 packs in parrallel, for plenty of runtime on whatever the circuit is going to power.
I'm thinking of installing the PCB into a Boom Box that runs on 12 volts. But I'm open to useful ideas.
What can we make rechargeable that normally isn't?
