Go Back   RC-Monster Forums > Support Forums > Novak
Ballistic 550's a reality
crazyjr
crazyjr's Avatar
Ballistic 550's a reality - 04.13.2010, 07:54 PM
Looks like Novak is making the 550 a ballistic motor, Wonder if they will offer anything in a 2500kv equiv.
http://www.teamnovak.com/products/br...550/index.html
gixxer
gixxer's Avatar
04.13.2010, 10:32 PM
Saw that on rccaraction and redrc. This should be great for the guys running 4x4 sct's. I have been running there 6.5 hv in my jammin for a month or so and it works great. Might still pick up one of these in a lower turn for the outdoor season.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Andrew222
04.14.2010, 05:16 AM
Can someone please clarify what the watt rating of the motors tells me?
The 5.5 turn ballistics 550 motor is rated at 800 watts and a 13.5 ballistics 540 motor is rated at 195 watts. So does that mean:
...that its going to drain the battery 4x quicker when I'm WOT vs ballistics 13.5
...that there 4x the torque throughout the entire power band vs a ballistics 13.5? Insane acceleration?
Can you use this motor in a MMP?
Please enlighten me...I'm stumped...
nuz69
nuz69's Avatar
04.14.2010, 10:23 AM
NO,
That means that the motor can handle more power IF IT HAS TO....
You will probably use only 400 or 500watts but with more efficiency, so for the same top speed, you should have same runtime...
NovakTwo
Senior Strategist
04.14.2010, 02:23 PM
In addition to the optional 7.5 wound stator, we can also offer whatever other winds customers want to use.
Such as 8.5, and maybe 3.5.
Novak Electronics, Inc.
ta_man
04.14.2010, 02:52 PM
You don't use more power than it takes to run the car.
Example: I ran a HV4.5 powered Slash 4X4 13 minutes (until the truck slowed down) on an off-road track using a 4500 mAHr LiFe (Turnigy pack). So my average amp draw was 4.5 / (13/60) = 20.7 amps. The average pack voltage (I know from discharging the LiFes at 20 amps) was about 6.3V. So, on average, the motor was using 131 watts.
I was using a MMP and you can too.
Andrew222
04.14.2010, 10:11 PM
so why would I want to go get a 550 motor instead of sticking with a 540 motor? If I'm going to average using 200 watts, is there any point in going with a 550 motor that I can't get 800 watts out of?
ta_man
04.14.2010, 11:01 PM
You wouldn't if you were running a 3.5 pound 1/10th scale buggy or truck. (Well, you probably wouldn't.)
But in a 5.8 pound SCT, a 550 has an easier time of it, and runs cooler, than a 540 motor. Lots of people are seeing temps around 170 to 180 using the 540 motors in a SCT. The HV motors run around 120-140 with reasonable gearing and will just last longer because of that.
Also note that the 800 watt rating is a peak power output for an unspecified (by Novak) period of time.
NovakTwo
Senior Strategist
05.10.2010, 12:49 PM
We will begin shipping the Ballistic 550s to our distributors later this week.
simplechamp
simplechamp's Avatar
05.14.2010, 03:05 AM
Any word on getting the lower kv winds into the lineup? If you had one at around 1800-2200kv I would love to try it out in my buggy. The only thing keeping me from trying the HV motors or new 550 Ballistics is the higher kv rating.
NovakTwo
Senior Strategist
05.14.2010, 09:27 AM
Winding stators for the completed motors we are shipping is our highest priority right now, but we will be adding replacement wound stators to store inventory soon. I just emailed manufacturing to see if we can add a few of this lower Kv replacement.
NovakTwo
Senior Strategist
05.15.2010, 10:02 AM
We should have these Ballistic 550 replacement wound stators (8.5 wind) in our store inventory in a week to 10 days.
JoFreak
JoFreak's Avatar
05.15.2010, 10:25 AM
Hey, I have the same combination. but haven't been able to drive it on a track yet.
What pinion and ESC / ESC-settings are you using?
simplechamp
05.16.2010, 03:52 AM
Do you have an idea of what the approximate kv rating the 8.5 wind will be?
NovakTwo
Senior Strategist
05.17.2010, 09:49 AM
I'll check and see if we have a Kv for the 8.5, yet
