Too old?
Beef
Too old? - 10.24.2010, 02:10 AM
Hey Guys, Ive got a nitro buggy that i want to convert to electric but ive bin told that the bearings wont be able to cope with electric? It is a old Hongnor buggy. Heres a pic. Click image for larger version
Semi Pro
Semi Pro's Avatar
10.24.2010, 02:23 AM
shim the diffs and it will be fine
its an older buggy but buggys didnt change much for 10 years, infact older buggys tend to hold up to power much better than the new generation of buggys because the older ones were designed like tanks, now its all about weight saveings and handeling
Beef
10.24.2010, 02:28 AM
thanks for the replay. What do you mean by shim the diffs?
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
10.24.2010, 08:16 AM
shimming the diffs mean you add very thin washers to each side of the differential to remove any play in the gearbox.
most differental shims are universal in size, but i'm not 100% sure about them being the right size on the older models..
http://www3.towerhobbies.com/cgi-bin...&I=LXCWP5&P=FR
http://www.amainhobbies.com/product_...Mayhem-Pro-RTR
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Beef
10.24.2010, 08:27 PM
Sweet. Which motor mount would fit my buggy? Would this one work? http://www.rc-monster.com/proddetail.php?prod=rcmcdmm
Also would this battrys tray work? http://www.rc-monster.com/proddetail...MFPbatterytray
Overdriven
Destroyer of Tires
Overdriven's Avatar
10.24.2010, 09:12 PM
Someone correct me if I'm wrong, but isn't Hong Nor the name Ofna uses in outside the US, particularly in Asia? That buggy looks like an Ofna LX series either way and while you could adapt the universal mount to your buggy, this one should just bolt in.
http://www.rc-monster.com/proddetail...od=rcmgtpmount
DwightSchrute
10.24.2010, 09:15 PM
that's a tough one. that one might work, but it would put your motor over the center differential and might alter the handling. that mount is more for monster trucks.
here is a univeresal mount that i've seen alot of the vintage guys use when they've converted a long gone nitro...
http://cgi.ebay.com/BUGGY-TRUGGY-NIT...item3f00726f12
it's not the prettiest design, but it will do the job. you can also make one out of stronger stock just by buying some aluminum angle on ebay. i made a dual motor buggy that way.
here's what i like to use for mine:
http://cgi.ebay.com/6061-T6-Aluminum...item2309056407
you can cut out the design using a scroll saw or a dremel and some files to clean up the edges. i've seen some elaborate versions of the ebay design that look pretty dam cool.
hope that helps.
DwightSchrute
10.24.2010, 09:18 PM
hong nor is the international ofna name, but i think the differential placement has moved in width over the years. it does look like an old ultra series though...i just don't know for sure.
