What center driveshaft lengths for RC-M CRT.5 chassis?
g-townmach
What center driveshaft lengths for RC-M CRT.5 chassis? -
08.22.2010, 10:59 AM
Just wondering what the center driveshaft lengths are for the RC-Monster CRT.5 long chassis.
I heard a while ago that the front is the same length as the stock rear, which is 82.5mm I believe. Just wanted to see if thats true.
If so, that would be super nice having the same length front and rear when it came time for replacing one or both of them.
g-townmach
2
g-townmach
12.07.2010, 08:47 AM
Does anyone have an answer for this??
It would really convince me to convert to the rc-m extended chassis if I knew the driveshafts were a readily available replacement part. Thanks.
g-townmach
3
silentsnow31802
01.12.2011, 06:00 PM
I just ordered one so I will measure the shafts when it arrives. I can also measure the stock ones if you would like.
silentsnow31802
Find all posts by silentsnow31802
4
01.12.2011, 06:15 PM
They are just rears IIRC from a normal CRT.5
Find all posts by Arct1k
5
silentsnow31802
01.30.2011, 01:29 AM
Just got my chassis today. It came with one driveshaft that is used for the rear. The kit has you use the stock rear crt.5 shaft for the front.
Rear shaft (came with kit) - 88.18mm
Stock rear CRT.5 shaft (now used for front) - 82.39mm
silentsnow31802
6
brainanator
01.30.2011, 02:38 AM
good info, thanks silent.
brainanator
Find all posts by brainanator
Linear Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
Off
