Inferno GT2 brushless
IGT_7x
IGT_7x's Avatar
Inferno GT2 brushless - 11.26.2010, 03:37 PM
Hey guys I need your opinions. So I'm ready to do another Inferno GT project but this time the GT2. On my GT1 I ditched the 2 speed and the mechanical brakes & just installed a single speed & let the ESC do the braking & it works flawlessly this time however I was thinking of using the RCM GT2 conversion kit which uses the 2 speed & mech brakes. What do you think is it worth it or just stick with a single speed?
whipnet
RCCOH.COM
whipnet's Avatar
11.27.2010, 12:15 AM
I am currently converting a DM-1. I am going to start with the 2-speed and mechanical brakes, but will most likely go with a single speed and motor brakes.
Beat your truck like it owes you money!!
RC Club of Houston
IGT_7x
IGT_7x's Avatar
11.27.2010, 01:58 AM
I think I'm going to stick with the single speed setup, I hear the 2 speed setup of the GT2 is not that good & the 2nd gear tends to get destroyed.
Bmr4life
12.07.2010, 04:11 PM
Pictures?
IGT_7x
IGT_7x's Avatar
12.07.2010, 06:01 PM
Bmr4life – Pics will come soon, all the stuff to make it is still under the tree but as soon as it's done I will post some pics.
NikoIGT
01.06.2011, 06:51 AM
You could use the new GT2 tranny:
http://www.infernosonly.com/New_Kyos...sion_s/832.htm
This works better, as there is only 3 tooth difference between 1st and second(doesn't hit as hard). you set the shift point fairly low(shifts early) to minimize the damage.
BIG-block
01.06.2011, 10:30 AM
I still say stick to the KISS theory (Keep It Simple Stupid). Why have all the extra moving components to wear and tear when you don't need to. Also if you use a decent ESC then ESC braking will not be an issue. If it can haul up my 13lbs Monster truck it can sure as heck pull up a 1/8th touring car. Also I don't see the benefit of using a two speed in a light weight car like an Inferno GT. Decent brushless motor will do fine without it.
IGT_7x
IGT_7x's Avatar
01.06.2011, 01:13 PM
Well pics will be up soon, I've been busy with the conversion but she's almost done. I did stick with the single speed as this worked flawlessly on my original IGT.
simplechamp
simplechamp's Avatar
01.06.2011, 01:32 PM
I want to say single-speed is the way to go for electric.
I think I can remember a discussion before about this. Some of the reason for nitro vehicles having a 2-speed is because nitro motors need to "wind up" to higher RPM before producing full torque. If you tried to start out in 2nd gear they wouldn't have very good acceleration, the nitro motor would get bogged down. So having 2-speed is effective for nitro.
For electric, the motor has full torque from startup, you can start from 2nd gear (or in most cases 2nd gear is just the main gearing, there is no high reduction 1st gearset)
01.06.2011, 02:27 PM
I am going to run a 2sp in my 7th scale on road car. Why? Cause I wanna go fast!!!!!!!!
Plus I have driven a few nitros that I converted with mech brakes and 2sp trans. If you drive it right and let off a little during the shift it will be just fine.
Meet the newest member of my brushless family
IGT_7x
IGT_7x's Avatar
Meet the newest member of my brushless family - 01.08.2011, 03:37 PM
Okay guys I promised pics of the new beast so here it is!!
Parts used for conversion:
RCM Kyosho motor mount
Kyosho single speed center diff
Mamba monster ESC
Castle/Neu 1520 1y 1600kv motor
RCM 14t mod 1 pinion
Kyosho Inferno VE receiver box & servo tray
RCM Inferno GT2 battery box
Aluminum arms
Team Sweep black wheels
Ofna on-road tires
Kyosho front & rear torque rods
Scanner RC 9764MG high torque servo
Spektrum RS300 2.4 GHz receiver
Spektrum DX3s TX
So what do you guys think? Now let's see how fast this beast goes!!
ID:	9601   Click image for larger version
ID:	9603   Click image for larger version
more pics
IGT_7x
IGT_7x's Avatar
more pics - 01.08.2011, 03:40 PM
Here's some more.
ID:	9606   Click image for larger version
ID:	9607   Click image for larger version
Semi Pro
Semi Pro's Avatar
01.08.2011, 04:51 PM
very nice car
2speed onroad is alot of fun, i still use 2peed off road on afew of my truck and i havent had many failures but i also am useing a clutch to absorb alot of the shifting impact
alot of people who have never used a 2speed in an eletric project hate on it and i dont know why, when set up right they are often just as quick, sometime quicker
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.08.2011, 04:55 PM
Looking good mang. That Aston body is my favorite.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
IGT_7x
IGT_7x's Avatar
01.08.2011, 05:10 PM
Thanks for the compliments guys. Yeah this car should be a blast. You can tell though that the IGT 2 is longer so with the Corvette body on it, it looks very scale. I used the single speed because it works really good on my original IGT & it goes ballistic on 6s. I do still use the 2 speed on my LST2 conversion & that thing as heavy as it is goes like a bat out of hell on 6s.
