Old drift buggy back in commision
tha5150
tha5150's Avatar
Old drift buggy back in commision - 01.30.2013, 08:49 PM
Been packed up for close to 4 years. Pics below. Was a drift setup but in all honesty I paid and a friend built. Plus the 4 years have only added to my lack of knowledge.
Here goes. Looking to transform this into a street car and not a drifter. Looking for Spur and Pinion gear advice and of course, tires. I would like to peel out a little bit but still grip on turns. Not on a track, just in the street.
Havok 8.5 - http://www.ehobbies.com/nov3038.html
On this car setup, what is my Pinion and Spur setup when using top of the line 4600MAH batteries when not trying to fry anying?
Ofna Hyper 8
Medusa AfterBurner 2300
4s Zippy Lipo
MMM
Stock Chassis
"still in training to stop hitting ankles"
tha5150
tha5150's Avatar
01.30.2013, 09:00 PM
TC-4.. Not buggy, sorry about that. I have another buggy I am making a post about also.
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
KMN
KMN's Avatar
02.16.2013, 12:17 AM
I still run TC-3's.... bought one brand new back in 99' or 2000..... Essentially the same car.
If I recall, I haven't checked it in years, but I run a 4600KV setup on 2S with a 69T spur and 20T pinion. Nothing ever gets hot, and it's an OG Castle system. I have been running it that way for over five years now and just run the piss out of it.
tha5150
tha5150's Avatar
02.17.2013, 12:03 PM
Sweet setup.
Was running the other day and no more rear power when on the ground. If I pick it up then the rear spins. Did I burn something up? All because of the new street tires lol
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
KMN
KMN's Avatar
02.19.2013, 09:29 PM
If it's not clicking, it sounds like a ball diff let loose. If it's clicking, you stripped a ring or pinion.
tha5150
tha5150's Avatar
02.19.2013, 09:36 PM
No clicking.where do I tighten?
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
KMN
KMN's Avatar
03.02.2013, 09:09 PM
You can get a 2.5mm allen wrench in one side and see if tightening it up helps. There's a bolt that goes through the diff and holds the balls, spring, washers, and d-rings in place. If that gets too loose, the diff will slip.
tha5150
tha5150's Avatar
03.04.2013, 03:03 PM
where at in this photo??
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
traxxasbasher13
03.04.2013, 06:34 PM
Its going to be inside one of the out drives of the diff. I couldn't tell you which side though, its been years since I messed with one of these. Just pop off the top ball cups and check each side, tighten it until it drives like you want it to. If it won't tighten enough, its time for a rebuild.
tha5150
tha5150's Avatar
03.05.2013, 10:46 AM
thx!
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
KMN
KMN's Avatar
03.08.2013, 09:36 PM
Long outdrive side, so it's going to be on the left hand side of the rear, and the right hand side of the front. If I remember correctly....
tha5150
tha5150's Avatar
03.09.2013, 03:26 PM
got it. problem solved. thanks guys
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
tha5150
tha5150's Avatar
03.09.2013, 03:30 PM
does this link work for you guys? if so, how much should i sell everything in these 52 pictures for?
https://plus.google.com/photos/11771...CI6w7KXSpLnmDw
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
brainanator
brainanator's Avatar
03.09.2013, 03:46 PM
Link works fine. That's quite a bit of stuff for us to give a price on. Your best bet is to add up the total it currently costs new, and knock it in half (or more/less depending on condition). Great condition can go for up to 80% of new, pretty beat up can go down to 25% or even worthless.
tha5150
tha5150's Avatar
03.09.2013, 03:58 PM
Thanks.. I will try to find a price. Going to be hard lol and time consuming.
Ofna Hyper 8
4s Zippy Lipo
MMM
Stock Chassis
