gear ratio
shawzie
gear ratio - 10.12.2007, 10:54 PM
Hi guys,I was wondering with the lightning diffs in the hybrid bulks would I keep the same gear ratio?or am I going to have to change anything?I am running the 3.3 but bought the hybrids so in the future I can go BB.I just don't want to lose any power and also not have to change a bunch of gears,I guess my question is will the lightning diffs fit right in and give me the same power as I have now.Thanks.
tashpop
10.13.2007, 08:23 AM
they are a lower gear ratio. you'll need to increase you pinion size, and/or decrease you spur gear. there is a real nice speed/gearing calculator in the sticky section under brushless.
10.13.2007, 11:52 AM
You can use the buggy ratio (43/13) gears which are close to the maxx gearing (37/13), than the truggy ratio (43/10). You should be able to compensate with a larger pinion or a smaller spur.
shawzie
10.15.2007, 01:47 AM
Does anybody else know other diff options besides the lightning diffs?Thanks.
wallot
wallot's Avatar
10.15.2007, 03:36 AM
kyosho 7.5 diffs, but hardened lightning ones are one of the best
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
shawzie
10.15.2007, 08:43 PM
would a ofna hyper 7 diff fit?Thanks for all the replies guys,I really appreciate it.
