Direct drive neu G3R
nl12
nl12's Avatar
Direct drive neu G3R - 12.12.2007, 06:56 PM
I am building a G3R for bashing, let me know what you guys think about this idea. I am thinking about mounting a Neu motor with a shaft coming out both ends between the rails on my G3R by putting drive cups on the shafts. I know I can order the motor in this configuration but I am not sure if I can get a KV low enough. I would probably get a 1527 with 8mm shaft. But even with truggy gears and the lowest 625 KV on 6S lipo topspeed is in the 50s. I would like it to be in the mid 40s and use a smaller 1521, I will have to see if neu can make me one with a kv in the lower 500s. If I decide to do this I will use a MMM controler when it comes out. Let me know if this idea is good or not I dont want to get a bunch of custom stuff and have it not turn out. If I dont do this I will wait for the G2 slipperential and use a regular Neu 1515 with the MMM. What do you guys think.
