e-revo - 5s lipo - up in smoke :(
DickyT
e-revo - 5s lipo - up in smoke :( - 03.23.2008, 10:55 AM
http://www.youtube.com/watch?v=C5-K6PbhOkU
the results of yesterday :(
xcntrk
xcntrk's Avatar
03.23.2008, 11:04 AM
What motor again? 1521/1Y? on 5s pulled more than 125amps and smoked the Quark or did the drivetrain lock-up or something?
I remember reading another member got some dirt/debris lodged in the spur gear out bashing and it locked the drivetrain at WOT and instantly smoked the ESC…
jnev
jnev's Avatar
03.23.2008, 11:33 AM
I think it was the Quark that smoked, right? And you had a Neu 1515/1y I think too. But that thing had some sick power.
lutach
lutach's Avatar
03.23.2008, 12:18 PM
That looked just like mine when it too put out a fabulous amount of smoke. When I went to unplug the battery, the wires from the ESC just came out.
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
03.23.2008, 12:54 PM
Awww man, that's like your 2nd or 3rd controller thats gone up! I feel for ya, I think I just blew out my Hyperion LiPo somehow. I might be making it into a 3 or 2s pack. Speaking of lipos, is that a True RC pack? How do you like it?
:D
brushlessboy16
brushlessboy16's Avatar
03.23.2008, 01:13 PM
you know hes got power if it needs that much blue smoke to run the esc :D
azjc
03.23.2008, 01:30 PM
I have a 4 cell 5000 True RC pack I picked up for $90 and for the money you can't beat them ... I believe they underrate thier packs...I would buy them before a MaxxAmps pack
DrKnow65
DrKnow65's Avatar
03.23.2008, 02:48 PM
Bummer, hate it when RC days end with dead components.
Wat hauling #$$ before it stopped though!!! Can't wait to have an ERevo...
DickyT
03.23.2008, 05:18 PM
I love the true RC lipo, it has never gotten above ambient temp. The drivetrain was fine, temps were air 85, batts 86, motor 115, esc fried
The motor is a 1515 1y, and lutach that is exactly what happened. I went to unplug the battery (which is ok) and the wire came right out
PowerRocks
03.23.2008, 05:36 PM
I wonder why people don't put an inline fuse between the battery and the esc. Use a fast blow fuse with the esc max amp. Probably need another one for the ESCs maximum continuos amp rating, but make it a delay type so that we can still acomodate the amp spike during acceleration.
03.23.2008, 05:38 PM
Bummer- at least it didnt go up in flames I suppose.
rchippie
rchippie's Avatar
03.23.2008, 05:53 PM
That's to bad about your esc, at least you did'nt have any flames. My friend smoked his MM the other day in his E8 buggy. His shot out flames thou
REAL MEN RUN BRUSHLESS
azjc
03.24.2008, 12:01 PM
I am thinking the Quarks esc fried due to internal heat, I have seen people needing to run external heat sinks and fans if they are running them above a 4s....that isnt very impessive for an esc that is suposed to be able to handle 6s....has anybody tried running an external UBEC and disable the units BEC....since I wasn't present when Dicky T's esc fried I don"t know everything that happened so its only a guess
Since I went to using the CC BEC and 4 cell lipo withe the Fiegao motor the heat to the MM is almost non existent
DickyT
03.24.2008, 12:48 PM
I had the rc-m heatsink on it, Ubec, and no fans.
rc-m heatsink was mounted to tekno mount, the quark to the heatsink with arctic silver paste, and a 2 zipties around the whole thing to holed the heatsink to the mount.
In previous testing runs prior to filming the esc temp never got above 125. I tested in loose dirt, asphault, grass, and sand. After a 30 minute run in sand was the hottest I had seen it was 125, and that was towards the end. I checked temps every 2 mins during the 1st 6 runs, every 5 mins during the second 6. this was the 7th run total and less than 2 mins in, poof. I'm going to call S&T here in a few mins to send it in for repair\replace.
david lamontagn
03.24.2008, 03:31 PM
Ouf!! you have paddle on it
MMust pull lot of Amps
