1521 vs. 1527
jordan...
one.five.two.seven
1521 vs. 1527 - 03.26.2008, 08:24 PM
hi everyone,
I think i'm going to get a Neu motor for my brushless UeG-maxx project. I've narrowed it down to the 1521/1.5D (1900kv), or the 1527/1.5D (1500kv). I'm planning on running 6s, and was just wondering which would be the better option. Would I be right in saying that 6s would not be enough to run the 1527 to its potential?
I'm going for all out power and insanity , so if anyone has advice on which motor would do the job better, please fell free to chime in
thanks in advance
jordan
satttheman
satttheman's Avatar
03.26.2008, 08:58 PM
check out my muggy im running 6s on a neu 1521/1y it did 57mph easy. check out the pics and the vid. i was think of try a 1527 in it glad i didnt the 1521 is plenty enough power the truck is crazy.
http://www.rc-monster.com/forum/show...t=10316&page=3
Projects:
FLM Savage
lutach
lutach's Avatar
03.26.2008, 10:54 PM
Yes, I would go with the 1521/1Y on 6S. I have since went to 5S.
jzemaxx
03.27.2008, 12:25 AM
I am running a 1521 1.5D on a 3905 emaxx on 6S its stupid, on 8S its super dumb and on 10S its worthless......choose wisely.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.27.2008, 01:50 AM
Yes, apparently higher voltage will quickly depreciate the value of your driving experience...
The 1521 will be plenty, unless you're a fan of broken drivetrain components.
jordan...
one.five.two.seven
03.27.2008, 06:15 AM
How'd you know, isn't everyone a fan of stupid amounts of power
If i was to run a 1527/1D (2300kv) on 6s, would that provide enough voltage, or would the amp load start to heat up the ESC??
thanks
jordan
Patrick
Patrick's Avatar
03.27.2008, 08:13 AM
What kind of esc are your going to use?
jordan...
one.five.two.seven
03.27.2008, 08:21 AM
hmmm... you know, i haven't put too much thought into that. At the moment it will be the MMM or the Quark SSB-mk03. Both seem pretty capable controllers from the specs that have been released to the public so far.
Patrick
Patrick's Avatar
03.27.2008, 08:38 AM
I doubt any of the quark esc's out at the moment will be able to handle a motor that size and kv on 6s. You could get lucky, but personally I'd try and get a bigger esc for that much power.
Not sure how my quark 125 compares to the new quarks, it does ok on 6s with a 1700kv 1515, though adding another 600kv and 30mm of motor is a big jump.
A guy at my track racing a truggy on 4s and plettenburg maxximum burnt out his SSB-mk03 during practice, but I'm not sure of the details of how it happened.
jordan...
one.five.two.seven
03.27.2008, 08:54 AM
My quark 125 does ok on 6s with a 1700kv 1515, but adding another 600kv and 30mm of motor is a big jump. A guy at my track racing a truggy on 4s and plettenburg maxximum burnt out his SSB-mk03 during practice, but I'm not sure of the details of how it happened.
wow, burnt out on 4s and a maxximum
maybe i should let others try out that ESC before i make a desicion on it . Well then, looks like the MMM... if its ever released...
what 'bigger' controllers are there, are you saying something like the MGM 16024?
How would a plane ESC go, such as one of the Castle Phoenix's, upto 12s lipo!! What would the truck be lacking though? It wouldn't have brakes or reverse with a plane ESC would it?
I think I'd definately want to wait for the MMM before trying to fit a plane esc to my truck though...
jordan
lutach
lutach's Avatar
03.27.2008, 10:49 AM
Don't go with the 1527. I have a 1527/1.5Y, but I'm actually not going to use it yet because the 1521/1Y already provides a ton of power. One powerfull controller would be the MGM 22418.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.27.2008, 01:27 PM
How are you liking that 1527 Lutach... Did Mike order that for you?.. I'm looking for 2x 1527/2.5D.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
lutach
lutach's Avatar
03.27.2008, 01:38 PM
I got it a while ago and haven't used it yet. The 1521 is already breaking stuff and I can't go with much more power. I already have a good stock of Universal Joints and I just need to get are some 43T Spiral Conical Gear, 10T Spiral Bevel Gear and Hard Steel Differential Gear Set, because I know they will go as soon as I get back to speed runs .
jordan...
one.five.two.seven
03.27.2008, 08:21 PM
TWO!! what are you going to be running those in?
How would a 1527/1D (2300kv) on 6s compare to that dual Pletty setup of hcr21, oh sorry, plettenbergs My drivetrain setup is pretty much the same to that, so i guess the weakest link would be the output shaft.
lutach
lutach's Avatar
03.27.2008, 09:27 PM
A 1515 will do you good, a 1521 will make you stock up of a few drive train parts and the 1527 might not be too fun if the drive train will not handle it, pls you will have to get a rock solid high AMP controller and some very, very good lipos to handle the kind of AMP the 1527/1D will pull. My 1521/1Y has pulled a max of 169A and the 1527/1D will go over that with no problem. This is the only reason why I still haven't put the 1527/1.5Y in my truck. I might go with one of my Aveox that is the same size as a Neu 1515 just to spare my drive train.
