New chassis for my t-maxx conversion...which one?
New chassis for my t-maxx conversion...which one? - 04.18.2008, 02:10 PM
Hi all...I am about to order a chassis from Mike and can't decide which one to order. Any feed back...good and bad would be appreciated.
Thanks
http://www.rc-monster.com/proddetail...LM16050&cat=45
http://www.rc-monster.com/proddetail...chassis&cat=17
http://www.rc-monster.com/proddetail...LM16040&cat=45
I will be using a center diff w/ a mount above the diff for the motor...hopefully Mike can make me one
Imo
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Imo - 04.18.2008, 03:08 PM
IMO since you are wanting to run a BL setup you might as well go with the FLM EMaxx chasis. Most of if not all of your TMaxx parts will interchange. I have one and it is a pretty good chasis for the money.
04.18.2008, 05:26 PM
I was leaning toward that one...I saw that Mike had made a center motor mount above the center diff and the set up was on a the FLM E-MAXX chassis which the forum member did a great with. Which drive shafts do you use?
04.18.2008, 05:40 PM
center mount came to me with driveshafts for $110
Choices
JERRY2KONE
JERRY2KONE's Avatar
Choices - 04.18.2008, 05:57 PM
Of course there are a few choices which are sometimes made by whatever is in stock at the time. Center dogbones can be had in a few places like UE, RC Monster, RC Alloys will make custom fit dogbones. Dirve shaft/axles can be picked up at UE, in 6mm or 8mm, R/C Monster has some, Kershaw supplies a couple kinds, or you can get a couple different ones on Tower. I am sure that there are more out there.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
which transmission are you using?.. if using the T-Maxx, how will the motor be mounted...?
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
04.18.2008, 06:59 PM
I will be using a HB center diff w/ an above motor mount...( as soon as Mike is available to make me one )
aqwut
aqwut's Avatar
04.18.2008, 07:24 PM
Well, get the E-maxx fastlane Chassis, lowered and extended...
