what's everyone's battery connector of choice?
mk351e
RC-Monster just don't get it
mk351e's Avatar
what's everyone's battery connector of choice? - 05.09.2008, 12:04 AM
I'm guessing deans ultra plugs. What do you guys use?
azjc
05.09.2008, 12:07 AM
all I use are Deans...I tried the Traxxas ones and went back to Deans
Deans for battery to esc, and either 4mm bullets or hard wiring from the motor to esc. On higher power setups I like to hard wire, one less thing to go wrong.
Mention was made about cleaning deans connectors from time to time, any suggestions on how to do this?
jnev
jnev's Avatar
05.09.2008, 01:17 AM
I use deans for battery-ESC connections and 5.5mm bullet plugs for motor-ESC connections.
big greg
05.09.2008, 01:20 AM
i use traxxas plugs, deans are to small and a pain in the a55 imo
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.09.2008, 01:38 AM
If you're going to be pulling 100+ amps, some 5.5mm, 6.0mm, 6.5mm plugs would be awesome.... but my favourite are still Deans..
All of my Lipos use 6.0mm, and deans for all the NiMH batteries....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
bluonyx
05.09.2008, 01:39 AM
I was wondering about this too. I use a little wire brush and simple green on the male end. To afraid to touch the female ones on the lipos though. Any suggestions?
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.09.2008, 02:20 AM
Deans plugs
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
05.09.2008, 08:35 AM
I'm using Deans plugs also.
david lamontagn
05.09.2008, 09:01 AM
5.5 bullet everywhere
brushlessboy16
brushlessboy16's Avatar
05.09.2008, 09:20 AM
5.5's and 4.0's to the motor and deans for the battery
lutach
lutach's Avatar
05.09.2008, 09:30 AM
I use a combination of Deans/5.5mm bullets for battery to ESC and 5.5mm to the motor in my BPP. The others are just Deans on the batteries and 4mm and 3.5mm bullets on the motor.
big greg
05.09.2008, 09:34 AM
man alot of deans, those things are a pain in the a55 imo, to small for my meaty fingers lol
05.09.2008, 10:13 AM
Depends on the current. Deans for anything that's going to draw ~30A continuous/100+A peak. For higher currents, either direct solder or 5.5/6mm bullet connectors.
The bad thing about bullets is that they are harder to "key" to prevent misplugging. And even if you do alternate the male/female ends, the battery side connectors can accidentally short on something when disconnected.
Deans really should make a larger connector. Make it the same way, just a little heftier and a little longer to make it easier to grip.
I usually dab a little of this like "degreaser" stuff on a buffing head for my dremel and just buff the male connectors a little bit. Then, I plug them into my Lipos and because the male connector still has a bit of degreaser on it, it cleans the female end in about 5min or so. DO NOT HAVE THE ESC POWERED ON IF YOU DO THIS! Then, unplug the connector from the female end, repeat the process on the male end because all of the crap in the female end has gotten onto the male end if this has worked correctly and once your male connector is clean after that, your Deans should be all clean!
