balancing tap questions
speed demon
balancing tap questions - 06.08.2008, 03:14 PM
I have an Icharger 106b which uses jst-xh tapps. Here is the bat I just bought along with a jst-xh tap with wires. http://www.rc-dymond.com/index.php?productID=1447 Question is what wires go where? I know where the positive and negative are and where they go on the jst-xh tap but I'm lost on where the middle wires go. Any help would be great.
wallot
wallot's Avatar
06.08.2008, 03:18 PM
balancing connector for 5S consist of 1 red and 5 black (or any other color in caseof many batteries with JST-XH connector)
they have to be in correct order - RED and all black with having 3.7V when measuring two adjacent wires. it should be in the charger manual
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
speed demon
06.08.2008, 03:29 PM
I checked and didn't see anything in the cd but will check again. Can you tell from the pic what connector that is? If I know that and find an adapter pic that would really be a big help.
06.08.2008, 03:53 PM
The tap on the battery looks alot like a hyperion tap. The wire order is the same on most taps, main pos and neg at each end, and the other wires should stay in the same order no matter what tap used.
gimpygolden
gimpygolden's Avatar
08.24.2008, 11:03 PM
How's this charger? I'm looking at getting one,do I need an adapter to balance a PolyQuest pack?
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
speed demon
08.24.2008, 11:11 PM
I really like it. It chargers my 4S,5S,and 6S really well. One thing I will warn you about is that on 6S charging over 3amps(ish) the screen goes blank. It freaked me out at first but seems to work normal. When the lipo is almost full and the amps trickle down the sreen comes back to normal. I added a 40mm 12v fan on the side and had the internal one running constant and nothing changed. Other then that I really like it but I thought I would tell you.
gimpygolden
08.24.2008, 11:14 PM
Are the JST taps same as Hyperion/PQ taps? Does anyone make adapters?
speed demon
08.24.2008, 11:20 PM
They are different. The jst-xh which the charger uses are more commonly called align tap. They are easy to find just make sure you get a male jst-xh(align) male end.
gimpygolden
08.24.2008, 11:21 PM
Cool thanks
