ok say i was wanting to make 36volts in an electric motorcycle. I was wondering wether three 12volt car bateries would last longer than 30 nimhs with a 600 watt motor and a 36 amp controller. So Witch batteries would get me more miles and last longer. thanks
car batteries are so much more powerfull than nimh's if you consider a weak car battery will have over 350cca's
And with car batteries, you can apply a constant trickle charge without hurting them, whereas any Li chemistry wants to see at the very least a CC charge with a voltage limit - ideally, a CC charge ending with a CV "top-off".
