1509's in a buggy...anyone tried it?
1509's in a buggy...anyone tried it? - 07.13.2008, 08:40 PM
Anyone tried this set up?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.13.2008, 08:45 PM
I assume you mean a 1/8 buggy?
I think it would be great for a racing setup. Lots of power for not a lot of weight.
Matthew_Armeni
Matthew_Armeni's Avatar
07.13.2008, 10:43 PM
The 1509's work great in a buggy for racing.
  Send a message via AIM to Matthew_Armeni
Edumakated
07.14.2008, 04:58 PM
They work well in lighter buggys on small to medium tracks. I have run a 1509 1.5y in my rc8 with no problems. However, if you run on a larger track I would go with the 1512. The low end torque difference is noticeable between the two. The 1509 also is not as forgiving gearing wise as the 1512.
TDC57
TDC57's Avatar
07.15.2008, 03:36 AM
I asked the same question a few weeks back in the buggy section and got these replies when I was considering one for my 808, http://www.rc-monster.com/forum/showthread.php?t=12970
The final item that persuaded me against it was Per BrianG RC calc, per the input your build needs to weigh under 7.7 pound in order to run a 1509 so I went with a 1512 instead and couldn’t be happier..
Best of luck in your quest..
Nothing!.. Hahahahaaa..
