Only the rears will fit. they have the same exact offset as the front electric rustler wheels. You can run them on all 4 corners, the rear will just be wider than stock.
The fronts are totally different
Cen ME16 Sidewinder 5700
CRT.5 MM + 1509 1y
FLM Rustler MM & 7L
E-Maxx Hv maxx 6.5 + FLM E-Maxx
Stock E-Maxx for friends to bash
8ight-t 1515 1y in the works
The jato fronts are the same as the nitro rustler fronts - If you change the front spindles this works well as it gets rid of the bushes for bearing - Similar to the RPM setup.
