does the kb45 8xl need the rcm clamp
Geogenesis13
RC-Monster Ruthenium
Geogenesis13's Avatar
does the kb45 8xl need the rcm clamp - 08.16.2008, 09:52 PM
like it say does it need it
"Its a bird."Its a plane.""It is my E-Revo and bl 5T you idiots."
brushlessboy16
brushlessboy16's Avatar
08.16.2008, 10:28 PM
it will not fit. different can diameter
Geogenesis13
08.16.2008, 10:32 PM
allright thanks oh would i need anything else to make it work in a erevo except for the single motor mount
MetalMan
MetalMan's Avatar
08.16.2008, 10:41 PM
The KB-45's bolt spacing is 30mm, and it uses 4mm screws. Standard 540 motors (36mm diameter) use a 25mm or 1in. bolt spacing, and 3mm screws. In other words, the KB-45 will not fit without modifying the motor plate, but even then there probably isn't enough material on the mount to let the motor sit properly.
08.16.2008, 11:00 PM
It will fit in an e revo, as the side mount has a 30mm hole spacing option that will fit a m4 thread bolt. Only issue is that the kb45 has a 6mm shaft, so pinion choice is limited. Mike may be able to get the mod1 pinions made with 6mm bore...
Kershaw designs has the 6mm bore pinions... in a few different tooth choices.
I have run the L can kb45 motors with good success. Not bad temps and they sure are powerful. They do draw some amps so good batteries are required.
Check here: http://www.traxxas.com/PDF-Library/5605_manual.pdf page 31
brushlessboy16
no problem :D
Geogenesis13
08.16.2008, 10:35 PM
alright thanks
Geogenesis13
08.16.2008, 11:03 PM
how many amps do you think they draw
08.17.2008, 12:03 AM
What voltage do you paln to run? I would say that a 6000mah 25c pack would be necessary for 4s.
For 5s and up a 5000mah 25c pack would be good. I would use enerland cell based packs, such as flightpower, polyquest, polyrc, thunderpower...
Stay away from maxamps, these motors will probably kill all but the 8000 packs..
Geogenesis13
08.17.2008, 11:21 AM
i plan to run 6s on the 8xl as well i know about maxamps do you think that the zippyh 3s 5000mah 20c packs would work or are the enerland packs the only way if so where should i buy them
08.17.2008, 01:30 PM
www.rclipos.com
Anything from there that fits the required spec.
Only is being that the erevo has limited space in the battery trays:
5000mah 20-25c 3s lipo that will fit will work well.
There is a youtube video of someone testing the Kb45 with a prop (bench mounted) to simulate a load- it pulled 130amps:
http://www.youtube.com/watch?v=wqN4fsWxKrU
Vids of the Kb45 in trucks:
http://youtube.com/watch?v=zxeY_ZqO504
http://youtube.com/watch?v=Mlc3gsyTQFI
ah-see
08.20.2008, 12:12 AM
Geogenesis, do some thinking for yourself. I'm sure you don't need your hand held to go to the toilet, so i'm sure you can figure out if the polyRC packs will fit into the e-revo.
Geogenesis13
08.17.2008, 01:49 PM
is that the continous load or the bursts
08.17.2008, 02:09 PM
I would aim for a battery that can handle at least 130amp cont....
I run the 8l kb45 in a 1/8 on road car, and it will push a pair of trakpower packs (4900mah 25c, 4s total) hard. You will run 6s, but you are also going to be spinning heavier tires, off road. These motors are great, and inexpensive, but will not like cheap bateries...
Geogenesis13
08.17.2008, 02:20 PM
is it okay for the batts to have 125cs constant
