Had an EPIPHANY during math class today
MetalMan
MetalMan's Avatar
Had an EPIPHANY during math class today - 08.27.2008, 04:05 PM
So there I was, sitting in a two hour lecture on infinite sequences/series by a British professor (funny guy!), and all of a sudden this hit me (attached):
08.27.2008, 04:12 PM
I don't get it, nice shading though
brushlessboy16
brushlessboy16's Avatar
08.27.2008, 04:20 PM
i see a slipper on the outrunner
Takedown
WARNING: May become violent.
Takedown's Avatar
08.27.2008, 04:23 PM
I also see a slipper setup on the outrunner but whats with the two shafts, diff and a solid gear?
RIP- Tammy (9/14/08)
MetalMan
MetalMan's Avatar
08.27.2008, 04:27 PM
Correct! It's actually two separate ideas, but I didn't want to draw two motors.
The top is in fact a slipperential with the slipper on the outrunner shaft and that drives a center diff.
The bottom is just a solid shaft.
I will have to explain myself later, for now I gotta get ready for work.
brushlessboy16
oh okay. why not just run direct drive :D
08.27.2008, 06:03 PM
With a geared setup you can maintain the center diff, use a slipper, and also use an outrunner that may not have the optimum kv for your intended battery and desired top speed. A smaller higher kv motor could be used with a smaller "pinion" on the slipper than the center diff "spur" (like a 36t revo spur on the slipper driving a 46t spur on the center diff)
Takedown
Takedown's Avatar
08.27.2008, 04:54 PM
Maybe he wants the nitro spool up feel.
Semi Pro
Semi Pro's Avatar
08.27.2008, 05:13 PM
so the out runner fits in the transmission, like on a revo
MetalMan
MetalMan's Avatar
08.28.2008, 12:18 AM
So is your idea putting the slipper on the pinion instead of onto the diff? Something like the LST slipper would be good for that as it seems to be able to handle power.
The slipper goes straight onto the motor shaft. Think of Mike's original Slipperential, but this will work with outrunners and decrease complexity. In my experience the Revo slipper clutch is actually quite good and highly adaptable, and I have no experience with the LST slipper.
Originally Posted by TruckBasher View Post
Interesting...well one good thing about outrunners is they promote innovation and not just traditional stuff...
I am yet to find out if it is innovation or just heartache of wasting time/effort
We will see if this effort is worth the time...
So basically, more gearing options. That was one of the things I didn't like about outrunners; you had to make sure to get it right because there are so few ways to adjust gearing
More gearing options is one of the main ideas I had in mind. Here's the deal - I want to use my 610 kv 4120/06 outrunner from my MT2 in my Corr truck, but on 3s Lipo I would need a kv of ~900 for direct-drive-to-diff to get the desired speed. But with this outrunner setup I can OVERdrive the "spur" gear and effectively acquire a higher RPM to the diffs.
There's no transmission here, or at least not in the traditional sense. Each part is standalone.
Five-oh-joe
08.28.2008, 10:14 AM
I TOTALLY fell asleep in Math yesterday for a few minutes.
08.27.2008, 07:23 PM
TruckBasher
TruckBasher's Avatar
08.27.2008, 08:15 PM
E-Slayer direct drive to diff
08.27.2008, 08:59 PM
IIRC, Patrick (pdelcast) made the apt comparison:
Two pole motors are like import 4-cylinders. They have high rpm/horsepower, but less torque. Neus are like domestic V8's, lots of hp and torque. And outrunners are like diesels with lots of torque but don't like the higher rpms.
I'm too lazy to go find the post, but it's along those lines.
Takedown
Takedown's Avatar
08.27.2008, 09:14 PM
Very well said Brian!
