servo problem...help!
VXL TACO
Owner of MaxxOrange
VXL TACO's Avatar
servo problem...help! - 09.15.2008, 07:52 PM
Hey guys, I just wanna clarify this. A few days ago I had a bad landing, and the Y-harness on my BL- Emaxx was caught in the spur gear and chewed up, part of it was still hanging by a thread, the mamba max engaged properly and the truck went forward and in reverse the right way, but when I tried to turn the servos would glitch REALLY bad and turn by themselves all the way to the right and keep making noises and twitching, but when I unplugged the Y-harness and plugged in one Lipo, the truck turned fine but did not engage the mamba max, thats because of the settings on it I know, but I think the problem with the servos is the Y-harness, so I just gotta get it resoldered right? Lol sorry for the long post, just gotta shed some light on this situation
" Any problem caused with a tank can be solved with a tank" - Peter Griffin
  Send a message via AIM to VXL TACO
09.15.2008, 07:54 PM
Well, since the problem started after the Y harness got messed up, chances are the harness is the culprit. I would get a new one - they aren't expensive compared to replacement parts if the servo doesn't work and sends you into a wall.
You probably have an intermittent or weak power, ground, or signal line where the spur cut into it.
VXL TACO
Owner of MaxxOrange
VXL TACO's Avatar
09.15.2008, 07:58 PM
Ok thanks, also why with one lipo plugged in the mamba max does not engage but the servos turn just fine? The settings on the mamba max? I have it set at 12v cutoff because I am running two 2s 4500 mah lipos, so with one 2s it probably cuts it off immediately.
