Possible bl conversion on rc10gt (old chassis) -
02.01.2006, 08:08 PM
well i won an old rc10gt on ebay for $61 it was arr only need radio...or so i thought....lol the motor doesn't run and the tank had a major leak in it so i stripped it and am planning on a bl conversion lol i was wondering if the feigao
Model: FG540L 3072KVM would be a good choice for the conversion
here are the stats:
Brand New, Never Mounted, in manufacturer's box
1 Motor
UHT (Ultra-High Temperature) Neodym Magnets
Balanced Rotor
Ball Bearings
Magnet Rotor Length 30mm
Shaft: 3.2 mm x 16 mm, flat spot for seating pinion
Weight: 285 gr (10.8 oz)
Dimensions (Diam/Length): 35.8mm x 60 mm
Internal Resistance: 0.0076 Ohms
Max Amps: 77
3072 RPM/V
8 turns
Up to 50,000 RPM
Up to 16 cells
and run it with the mgm compro or something with a maxamps 2S2P 6000mah 7.4V Lipoly Pack...
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
