Problem LI-PO cut-off
virusss
virusss's Avatar
Problem LI-PO cut-off - 11.16.2005, 09:02 AM
Hallo boys i have a question, whit my setup 7xl-20120 micro, 2 packs of thunder power 3s4p 8000,the 20120 do not have the cut-off adjustable, as I make not to unload the lipo excessive? They are not successful to find of the cut-off external for these voltages, the only one that I have found supports until 4C LiPo.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJDJ0&P=7
MetalMan
MetalMan's Avatar
11.16.2005, 09:40 AM
How about this one:
http://66.241.195.91/lithium/lithium.asp?path1=lithium
virusss
virusss's Avatar
11.16.2005, 10:08 AM
Saver works with 2-10 series cell packs :(
I have 6s lipo=18 cell classic
MetalMan
MetalMan's Avatar
11.16.2005, 10:13 AM
The Li-Saver works with 2-10 Lipo cells.
virusss
virusss's Avatar
11.16.2005, 10:14 AM
oooppps thanks much :)
crazyjr
crazyjr's Avatar
11.16.2005, 03:49 PM
Hey Metalman. The extra wire goes to the pos/neg of the battery, right.
squeeforever
squeeforever's Avatar
11.16.2005, 04:29 PM
what about then you dont want to run lipo and you wanna run nimh? if i were to use something like that i would want it soldered. what would i do if i was to run nimh? just unplug i from the esc and the reciever and the esc up to the reciever like normal?
Serum
Serum's Avatar
11.16.2005, 07:17 PM
Yes, it does Crazy.
squee, what are you saying, it's a bit misty.. i presume it's about the one from towerhobbies you are talking about? seems to me like it's an auto sensing one..
MetalMan
MetalMan's Avatar
11.16.2005, 07:18 PM
Squee, yes, you would just unplug the LVC from everything and plug the controller in just like you would normally.
Serum
Serum's Avatar
11.16.2005, 07:27 PM
It just measures then, but it can't do anything anymore with that information..
