Balancing Nue batts with TrakPower v-balance
mkrusedc
NeuMaxx
mkrusedc's Avatar
Balancing Nue batts with TrakPower v-balance - 11.23.2008, 10:46 PM
How do I balance a NeuEnergy 5s battery with a V-Balance from TrakPower? Is it as simple as plugging the NeuEnergy's tap into the V-Balance?
The NeuEnergy has a 6 pin female tap. The V-Balance has an eight pin plug. Should I put the tap close to the positive lead Like the TrakPower tap. That way the black lead will be on the same pin?
Thanks
11.24.2008, 03:34 AM
Well, neuenergy lipos use kokham taps, IIRC. And the v balance is setup to use fp adapter pigtails, not sure if they make one to go to kokham taps.
With some modding you could make this board work: http://www.amainhobbies.com/product_...ducts_id/28927
but you also need the cable, which only appears to be sold with the polyquest board: http://www.amainhobbies.com/product_...ducts_id/20719
I have everything listed, I can try to make it work tomorrow and let you know...
mkrusedc
NeuMaxx
mkrusedc's Avatar
Question 11.24.2008, 10:30 AM
You were up late.
Thanks for the reply. The pig tail on the V-Balance can be unpluged. When I do that the balancer itself then has an eight pin male plug. I might not have to modify anything if I just knew what the pins were for. The Neu tap has six female pins. Can it be as simple as just pugging it in?
11.24.2008, 12:49 PM
I was up to 3am, went to the Metallica concert last night and got home late.
Here are a few pics. I just plugged the adapter harness in and left the 8th pin (closest to the pos charge lead) exposed. Works fine with a 3s pack, I do not have a 5s pack to try.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.24.2008, 01:07 PM
Thanks. I'll try tonight without the adapter. I'll let you know what happens.
I wanted to go but family obligations got in the way. Were they good?
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.25.2008, 12:17 AM
Well it doesn't fit without the adapter board....
11.25.2008, 03:05 AM
It was a decent show, quite long. Their light show was good, but it had a bit too much light shined in my eyes...
Yeah, the spacing is different, huh? Gotta get the adapter board...
