need a couple MMM measurements....
rootar
rootar's Avatar
need a couple MMM measurements.... - 12.02.2008, 08:35 AM
well i forgot to get these while i had one here i need to go ahead and make my mount but i need these two dimension that are labeled x, y, and z in the pictures below, thanks alot for the help guys.
Name:	track 054 dimensions.jpg
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
12.02.2008, 08:40 AM
X=33mm, Y=33mm, and Z=10mm. Hope that helps.
rootar
rootar's Avatar
12.02.2008, 08:45 AM
thanks , im guessing its a 30mm diameter hole for the fan?
Dagger Thrasher
12.02.2008, 08:49 AM
Well, the fan is 30mm and the outer fan housing is 33mm total, and a 1.5mm wall thickness sounds about right. So without opening my case, it's probably just slightly more than 30mm (to allow 30mm fans to fit snugly) internally.
