VXL Rusty w/Proline 30 Series?
Fast5sRevo88
VXL Rusty w/Proline 30 Series? - 12.20.2008, 08:53 PM
I want to use Proline 30 series rims and tires on my e-rusty, but as most of you know the rusty has back hexes up front instead of the stationary spindles that the Jato and nitro rustler use, the 30 series is only compatible with the Jato, Nitro rusty, and nitro pede. So my question is, could i just get 2 sets of rear jato rims and put a rear pair on the front of the rusty or would they be the wrong offset?
jayjay283
jayjay283's Avatar
12.20.2008, 09:13 PM
I run 2 sets of rear Jato Anacondas on my rustler, the offset will be "off" (not equal front and back, rear will stick out more..its not that bad but they are off unless you get the FLM extended front aarms. This company is making foams in offset for them http://www.jacoracing.net/newitems_foam_rubber.html
Fast5sRevo88
12.20.2008, 10:28 PM
Ok, that is helpful for sure. I really want some of those Jaco's for aspault, but i do see alot of offroad so i do need some 30's for that in Dirt Hawg tread. I could use some flm extended arms up front, they would also double as a wheely counter-weight.
skellyo
skellyo's Avatar
12.20.2008, 11:47 PM
The FLM front extended arms make it perfect for the 30 series:
4u2nv
12.20.2008, 11:48 PM
Why not just switch the front over to the Nitro setup with the spindle. That's what I did on mine.
Gee
A Horse's Ass
Gee's Avatar
12.21.2008, 09:33 AM
I did the same thing with my rustler. They are stronger then the setup the rustler uses. I sure don't miss all those bent king pins I use to have change out.
12.21.2008, 10:09 AM
Ditto with my pede... you can use the 17mm jato adapters then...
Fast5sRevo88
12.21.2008, 03:17 PM
I'm assuming ya'll used the spindle setup from the Nitro Rusty?
Fast5sRevo88
12.21.2008, 04:03 PM
It looks like u also have the standard length FLM arms on the back? And of course the extended ones up front.
