Originally Posted by Cain
JHauz, keep us posted on how handling is.
BY the way, for the nice low wire job you did on the motor to ESC connection, what are you using to hold the wire down when you put the zipties on?
Hopefully I'll get to race Sunday and I can let you know if it changes the handeling. By hand I cant tell that it flexes less it still seems to have anough give so I dont think it will have to much effect.
For the wires its pretty much just gravity. I use a zip tie cable mount thing right behind the motor to keep the rigid motor wires from moving around. When you bundle the wires together like that it makes them pretty stiff so they dont move realy. I use to mount the wires up high going over everything and try and keep it from getting pulled down, but then I just figured why fight gravity when I can use it to my advantage.
Havent had any issues with it moving at all.
