Losi Truggy Q
fastbaja5b
fastbaja5b's Avatar
Losi Truggy Q - 02.18.2009, 10:22 PM
Hey lookin at doing a Truggy conversion
is a Neu 1512 2.5d sufficient for the Losi Eight-T or is it going to be too small?
Looking at 4-5s Lipo with a MMMV3
Say Less, Do More.
js058515
Thank You Brushless Gods!
js058515's Avatar
02.19.2009, 12:15 AM
I have a 1512 as a back-up motor for both my 8T and 8B. It will move a 10lbs truggy with no problem. I used the 1512 in my ST-RR and it still had plenty more power than I needed. On 4S the 1512 2.5 will be at 30k rpm and at 5S it will be around 37k rpm and those are both good numbers.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
02.19.2009, 12:26 AM
The 1512 might be ok if kept geared low enough, but typically the 1515 series is a more common choice. You can get a kv equivalent to the 1512, but the added surface area of the longer motor will keep it cooler.
fastbaja5b
fastbaja5b's Avatar
02.19.2009, 08:34 PM
ok so I figure a larger motor, would you suggest the 2200 or 2650 Castle?
We have to use a max of 4 cell in racing these
Also any clue on gearing?
Say Less, Do More.
