my gear box and chassis fit...
jocktheglide
my gear box and chassis fit... - 01.06.2006, 06:29 AM
man my gear box had a tight fit the rod (shift fork guide) had a hard time going into the hole I had to modify the hole a bit. Same with the bulkless setup there are two pins that the hole were too small for, but I got them in. Also the gear box does not sit perfectly on the chassis there is a little hump in front, but other than that the whole setup is nice I will take pics when im done with everything.
Sylvester
Sylvester's Avatar
01.06.2006, 11:47 AM
Good to here you got everything in there in one peice, as for the pins in the bulkless, if its too tight you may lose some performance in your truck as it will make the shocks work a bit harder, are you talking about the suspension pins or which ones?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
jocktheglide
01.06.2006, 12:15 PM
the bulkless setup has two pins and they go inside the diff case dont know why you would need it, but those are a pain had to machine a bigger hole.
Sylvester
Sylvester's Avatar
01.06.2006, 01:01 PM
Oh, ok than thats ok it can be a little tight.
Losi 8ight e
mmdooley
mmdooley's Avatar
01.10.2006, 12:55 AM
What are you talking about " a hump in front"??
WE DON'T STOP PLAYING WHEN WE GET OLD. WE GET OLD WHEN WE STOP PLAYING.
