Tekno X2 Conversion
Tekno X2 Conversion
Fast5sRevo88
Tekno X2 Conversion -
03.11.2009, 04:09 PM
Will the Tekno X2 conversion kit for CRT work on my X1?
Fast5sRevo88
2
skellyo
03.11.2009, 04:14 PM
Any reason you don't consider Mike's motor mount and battery tray? It's a bit cheaper and the battery tray is a lot nicer IMO.
skellyo
Find all posts by skellyo
3
Fast5sRevo88
03.11.2009, 04:43 PM
I have that stuff already and like it, i was just wanting to try something different.
Fast5sRevo88
4
teknorc
03.11.2009, 06:05 PM
Originally Posted by
Fast5sRevo88
If you have the newer small center diff setup and the f/r truggy diffs, it will fit right up. It is not compatible with the larger spur gear from the X1 however.
Tekno RC - Performance Parts
teknorc
Find all posts by teknorc
5
skellyo
03.11.2009, 08:33 PM
If the center diff itself is the same from X1 to X2, you can swap the 62T stocker on the X1 out for a 46T Kyosho spur.
skellyo
Linear Mode
Switch to Threaded Mode
