Any grade 12.9 or if you can do it, drill and tap it for 4mm.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
I guess the countersunk holes are for motor screws, then it mounts with the other threaded holes?
Is there one that catches all four screws on a Medusa? They have 2 on 25mm centers, but the other two are on 19mm centers.
Yep the medusa one fits all 4 threaded holes. I have one and it fits my 60mm v2 perfectly. A very good idea, as one of the threaded holes in my motor stripped out very easily. Use the drop down menu to select the medusa model.
