Pinion gear red or bue loctite ?
samintrepid
samintrepid's Avatar
Pinion gear red or bue loctite ? - 03.09.2009, 12:47 PM
The pinion gear on my savage flux come loose couple of time after i put a blue loctite, i want know if is too dangerous to put a red loctite on set srew or is better to clean pinion and set screw and reapply another blue ?
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
03.09.2009, 01:09 PM
I'd say there's another problem if blue won't hold it. I don't even use any loctite on my pinion grub screws. Never needed it. I'd check alignment, mesh and look for vibration.
skellyo
skellyo's Avatar
03.09.2009, 01:14 PM
I'd clean them both and reapply the blue. Also be sure that you're using a high quality hex driver than you can torque it down with.
03.09.2009, 01:19 PM
Blue has always held well for me. IIRC, lock-tite does get weaker with high temps, so if the pinion is getting hot enough to weaken the bond, maybe the mesh is too tight?
samintrepid
03.09.2009, 01:39 PM
I have burned 2 slipper pad and the spur gear become extremely hot i think is that and for my gear mesh i have put paper just like the manuel said and now i have buy a new pad and some 4mm bolt for slipper.
skellyo
skellyo's Avatar
03.09.2009, 01:46 PM
You may want to tighten the slipper down more. Mine got loose after a couple of packs and the spur got stupid hot. After that I pulled it and tightened it all the way and then backed off about 1/4 turn. No problems since then, even running on 6S.
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.09.2009, 02:34 PM
Tighten the slipper like skellyo said. I run mine 1/8 loose. Clean and reapply blue loctite.
MetalMan
MetalMan's Avatar
03.09.2009, 02:37 PM
Another thought - Is the set screw old? They have a sharp edge (cup) on the bottom that allows them to "bite" into the motor shaft. Over time this edge wears out and can allow the set screw to loosen up a lot easier than if it were new.
DARKWAV
03.09.2009, 04:15 PM
I've never needed loctite on my pinion set screws until I graduated up to these high voltage brushless MT systems! That was a rude awakening. Since then blue has worked fine for me
fastbaja5b
fastbaja5b's Avatar
03.09.2009, 07:44 PM
I use the Blue loctite and it's fine, just check your set screw with a hex wrench before each run as well.
Say Less, Do More.
shizzon
shizzon's Avatar
03.09.2009, 07:55 PM
you should wait alt least 2 hours after applying to use the truck, preferably over night. If used right after applying most of the thread lock will fly off.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
Jabe
03.10.2009, 06:28 AM
You can try applying loctite betwene shaft and pinion also.
Also clean threads on pinion and change to new set screw.
Freezebyte
05.08.2009, 10:00 PM
Dunno about you guys, but I got farking sick of my pinion gear set screw coming out on my new Savage Flux, damn thing came out 4 times after only two drives. Co I cleaned it and red loctited that SOB in their. Now it should be going nowhere
Always Dreamin
05.08.2009, 10:12 PM
What is the problem with red lock-tite? Aren't all the colors made to break their seal at high temps?
not saying he should use it, just curious. For the record, blue lock-tite has always worked for me.
entjoles
05.08.2009, 10:15 PM
as others have said , only blue imo
also helps to let it set up for about 1 day if you havent
