2650 kv bearing size ??? -
05.27.2009, 03:09 PM
hey ,
i was driving my crt.5 with the 2650kv motor today then suddenly the motor stopped working and i check it it turned out that the front bearing broke , is this covered by warranty by castle if i only have the receipt from my lhs ??? if not where can i order a front bearing for it ????
thanks
05.27.2009, 03:41 PM
They are under a year old so yes - just send it in...
05.27.2009, 03:56 PM
was the bearing "RUSTED" lol sorry i couldnt resist
05.27.2009, 04:11 PM
Wow, a 2650 in a CRT.5! The motor must weight more than the vehicle.
05.27.2009, 04:18 PM
loool , nah it wasnt.
yes, my crt.5 needed a motor since those cheap hobby city motors didnt last 1 and a half week , and the 2650 was sitting in the box so i said y not put it on the crt.5, first the bearing on the rear hub broke , then the bearing on the motor
05.27.2009, 04:22 PM
Ever put a couple drops of lube on them?
05.27.2009, 04:36 PM
nope , it basically like new , ive only tried it twice on my buggy, then sold my buggy and the motor sat in the box for a couple of days then i put it on the crt.5, at first i thought that the shaft or gears broke but was surprised that it was the motor
RC Addict
05.28.2009, 02:30 PM
Hello,
I swapped out all the bearings in my 2650 and 2200 for ceramics from Boca. The rear cover does come off, but when I did the epoxy pulled off some electrical tape that is wrapped around the wires coming out of the motor. I easily added some new insluation (shoe goo) and off I went.
Motor is very smooth, and very cool.
I used these from boca.
http://www.bocabearings.com/main1.as...MR625C-YUU_NB2
I will post pics tonight
If you can't be good, be bad!
05.28.2009, 02:59 PM
I was also curious, what sized bearing do we need to replace the Tork Flux motor ones?
05.28.2009, 03:02 PM
It will be the same. The Tork motor is a CC2200 with a different can.
RC Addict
05.28.2009, 03:07 PM
I am assuming that they run they 5x16x5 bearing as well.
05.28.2009, 03:25 PM
Which is what?
RC Addict
05.28.2009, 03:29 PM
Which is what?
The tork 2200kv is the same motor as the neu castle 2200kv, but is black instead of green
05.28.2009, 04:13 PM
Arrrrgh, I meant what size are the dumb bearings!!!
RC Addict
05.28.2009, 04:15 PM
5x16x5
5mm - inside diameter
16mm - outside diameter
5mm - thickness
I know this for sure as I have replaced my castle-neus bearings. The front and rear are the same size.
