2650 kv bearing size ???
Freezebyte
05.28.2009, 03:25 PM
Originally Posted by
MetalMan
It will be the same. The Tork motor is a CC2200 with a different can.
Which is what?
Freezebyte
2
prhess
RC Addict
05.28.2009, 03:29 PM
Freezebyte
Which is what?
The tork 2200kv is the same motor as the neu castle 2200kv, but is black instead of green
If you can't be good, be bad!
prhess
Visit prhess's homepage!
Find all posts by prhess
3
Freezebyte
05.28.2009, 04:13 PM
prhess
Arrrrgh, I meant what size are the dumb bearings!!!
Freezebyte
4
prhess
RC Addict
05.28.2009, 04:15 PM
5x16x5
5mm - inside diameter
16mm - outside diameter
5mm - thickness
I know this for sure as I have replaced my castle-neus bearings. The front and rear are the same size.
04:19 PM
prhess
5
Freezebyte
05.28.2009, 04:34 PM
Ah ok, perfect. I wonder what are the best bearings I could put in the Tork motor when it comes time to do so?
Freezebyte
6
prhess
RC Addict
05.28.2009, 05:10 PM
Freezebyte
There were the best I could find
http://www.bocabearings.com/main1.as.../C3_Z/S_#5_AF2
- 99.99 a piece
or
http://www.bocabearings.com/main1.as...=SMR625C-ZZ_#3
- 17.99 a piece
But I went with these due to cost
http://www.bocabearings.com/main1.as...MR625C-YUU_NB2
- 11.99 a piece
05:13 PM
. Reason: added
prhess
Hybrid Mode
Switch to Threaded Mode
Off
