Originally Posted by E-Revonut
The Mod1 gears for a Revo 3.3 are to small, you would need about a 30+T pinion to reach the spur. An associated MGT 52T spur can be modded to work but you may still have gearing limitations. IMO just get 1 or 2 32p pinions and the 54,56,58,62,65,+68t spurs, the spurs are only about $3 and with 2 different pinions that would give you a wide varriety of gearing options. I just sold 3 different 32p pinions and gave away all my spurs since I sold my E-revo a couple weeks ago.
I used to run 22/40 gearing with Mod 1 using an AXI 2826/8 outrunner motor. Pretty good setup for short tracks.
Now I'm running a Medusa 36-60-2000kv using 18/52 Mod 1 gears. It's easy to Mod a MGT spur.
Choose three of the peg holes and drill them out to 5mm, I think it is. Then you have to enlarge the center hole to fit the carrier bearing.
The Beauty of this is, they don't wear out and can handle huge torque loads. You can also get the MGT spurs made out of Delrin.
Delrin is double tough stuff.
The MGT spur in my Revo has seen probably 50 packs and shows no wear.
I love it.
