Brushless Motor & Solder Gun
aqwut
Brushless Heavy Weight....
aqwut's Avatar
Brushless Motor & Solder Gun - 07.17.2009, 11:48 PM
Hey Guys,
While desoldering my connectors off of a dead motor, check out what happens.. Would that be single phasing?..
http://www.youtube.com/watch?v=Kx73b...eature=related
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.18.2009, 12:08 AM
LOL
Yup, the difference in voltage between the two points on the resistive soldering tip makes it possible to cause a short circuit into the motor, only a small current im sure. Better watch out though, you could overload the coil inside the soldering iron...
aqwut
aqwut's Avatar
07.18.2009, 09:47 AM
really will it overload the solder gun, even though that the ends are closed circuits...
zeropointbug
Z-Pinch racer
07.18.2009, 12:35 PM
Well, probably not, you would most likely have to do that for a awhile...
