Closed Thread
Almost new Castle HV-110 ESC controller
jzemaxx
Almost new Castle HV-110 ESC controller - 07.23.2009, 02:17 PM
This controller is a spare I have that I no longer need. Great for the guys wanting to do brushless setups and run High voltage and manual brakes, or for RC Airplanes or Heli's. Specs are below...
This is the Castle Creations Phoenix HV-110
High Voltage, Brushless, Sensorless Electronic Speed Control.
FEATURES: Handles up to 36 NiMH/NiCd, cells or 12S LiPo (50V) maximum, 16 cells
NiMH/NiCd or 3S LiPo minimum
Up to 110A continuous current
Forward and reverse
Auto Shut Down when signal is lost or radio interference occurs
Smooth reverse exponential throttle
Audible Arming Signal
Self-calibrating endpoints: maximizes usable stick travel
Over temp motor cut-off with reset
User programmable options include:
Low-voltage cutoff with Auto-LiPo detect as default
Over-Current Protection
Brake Type
Throttle Range
Timing Advance
Cutoff Type
Soft Start ramp up prevents damage to gearboxes
Switching Frequency
INCLUDES: One Phoenix HV-110 Electronic Speed Control with 10AWG motor and
battery leads, Universal receiver connector and set up manual
REQUIRES: Receiver battery pack, Dual Opto-Coupled (no BEC)
Motor and battery connectors of modeler's choice
SPECS: BEC: None (dual opto-coupled)
Maximum Cells: 36 NiMH/NiCd, or 12S LiPo (50V)
Continuous Current: 110A
Minimum Cells: 12 NiMH/NiCd, or 4S LiPo
Switching Rate Programmable: 13, 26, or 52kHz
Resistance: .001 Ohm
Brake: Programmable
Reversible: Yes, change any two wires
Low Voltage Cut-Off: Programmable
Size: 1.55"" x 2.8"" x 1.25"" (39mm x 71mm x 32mm)
Weight (with wires): 5.3oz (150g)
Receiver Connector: Universal
jxs 9/01/05
ir/jxs
This is the same controller I used to set the monster truck speed record. This was the spare I bought. Also the controller was only turned on to verify it was operational when new, but not ran or mounted in a moving RC.
http://www.youtube.com/watch?v=ERY9_TLF86M
PM me for pricing.....
ID:	7461   Click image for larger version
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Closed Thread
