mmm wont work with castle link???
brox1j
mmm wont work with castle link??? - 08.04.2009, 11:37 PM
Well i finally got a MMM for my losi eight-e but it doesnt want to link to my castle link. I got it to work one time but it was after closing and opening the castle link several times. I havent been able to make it work since any ideas on what it might be???
Foxracin
08.05.2009, 09:52 AM
Sometime I have to unplug mine and plug it back up a few times before it recognizes it. Not sure why but everything else is good.
emaxxnitro
emaxxnitro's Avatar
08.05.2009, 02:41 PM
are the wires backwards on the rx plug?
808E
08.05.2009, 04:31 PM
I have run into this one before using vista....call castle and they will walk you through a simple step of renaming a file. It worked for me the first 2 times and then the castle link stopped working. After I called, prob. solved
ksb51rl
08.05.2009, 05:10 PM
He is using Windows XP Pro.
08.05.2009, 05:11 PM
Do you have a different CastleLink device to try? And maybe a different USB cable? These intermittent things usually points to something mechanical (broken wire, loose solder joint, etc).
simplechamp
simplechamp's Avatar
08.06.2009, 10:10 AM
Agreed. First rule of PC hardware troubleshooting: If in doubt, trade suspected bad for known good.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
08.06.2009, 01:54 PM
One time my MMM didn't work with castle link, but when I switched the on/off switch to on, it worked.
Area 52 Ranch Raceway
T.R.C.R.
brox1j
08.06.2009, 03:13 PM
The wires are plugged in the right way. The esc light up yellow when I plug it in but the castle link doesn't read my esc
