Originally Posted by Brushless Moose
will the 45t plastic spur for the 2.0 ft the 1.0? will a standard 5mm bore mod 1 pinio work?
none of the plastic spurs fit. they're too thick. you need to sand like 1/8" off of the face for them to work in the center diff. why losi used these thick spurs, i'll never understand.
the other alternative is to buy the steel 45T spur. that'll fit with no mods.
yes, a standard 5mm bore pinion will work.
EDIT: losa3552 is the part # for the steel spur.
