brushlessboy16
brushlessboy16's Avatar
08.31.2009, 01:11 PM
the kyosho spur does not fit
it is also too thick.
I tried...
stick with the steel one, and get an rc-monster pinion and its not loud at all
Brushless Moose
08.31.2009, 02:47 PM
yeah, but what is the biggest spur I can use? The stock one (i.e. the one that is on it now, I think a 48 will work with the RCM mount?
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
08.31.2009, 05:05 PM
The stock steel 48 spur WILL work with the RCM Mount.
Direct drop in. NO MODDING or GRINDING. I dont know why the dwite guy said it wouldnt. I am running it right now...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
Brushless Moose
08.31.2009, 05:20 PM
sweet. thanks. I was wondering why it wouldn't
Brushless Moose
08.31.2009, 08:21 PM
can anyone confirm that the stock spur does or does not work?
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.31.2009, 09:51 PM
Since i've never tried to fit a 48 on there and have only gone on the word of dozens of other menbers who've said 45 is the biggest on a stock chassis.......here's a close up photo of my 45t spur. look at the chassis and the gear. do you really think i can get 3 more teeth?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Brushless Moose
09.01.2009, 12:04 AM
what spur are you using? THe kyosho will fit? I want to order now but am getting confused...
jsr
09.01.2009, 12:31 AM
Kyosho has a 45T? I always thought it came only in 44T and 46T.
Brushless Moose
09.01.2009, 12:53 AM
ok, 46t. I was confused. Do you know if the stock metal spur works, as you can see, we have conflicting opinions, also, will either of the kyosho spurs work?
ZippyBasher
09.01.2009, 11:03 AM
I am saying YES because I HAVE it INSTALLED and have run it like 10 times no problems....
Did you add the metal spacer under the plastic diff brace? it raises the center diff by 1/4" or so and now clears chassis prefectly
D8T - MMM 1717 6s
DwightSchrute
09.01.2009, 02:13 PM
yeah, i put the spacer under the plastic brace. if you say a 48 fits, then i guess it fits. i just wouldn't have thought so after running a 45. i guess most other people who did the conversion just stuck with the 45 the conversion provided.
Brushless Moose
09.01.2009, 02:16 PM
I am wondering, are there any instructions or tutorials for the RCM conversion? I a unsure how everything mounts up...
DwightSchrute
09.01.2009, 02:28 PM
4 screws on the bottom 4 on top....it's that simple. really. this conversion is as easy as easy can get. are you the same brushless moose from the traxxas boards?
Brushless Moose
09.01.2009, 02:59 PM
yep. So it just directly replaces the center diff mount?
DwightSchrute
09.01.2009, 03:51 PM
i'm vxlrocket from the traxxas boards...i hung out mostly in the rusty forum, but i remember you from the revo forum.
to answer your question...yeah. exactly. you'll see once you get everything. any issues, and any of these guys will walk you through it. i'll even take one apart and do a pictorial of the build if you need it, just let me know.
i know you had a revo, right? weren't you the original thread starter of the fastest revo contest?...the 8ight is 1000 times easier to work on. i literally needed no instructions.
any questions, just ask away moose!
