on the Sr3300T spektrum rx...a question -
02.06.2010, 10:47 PM
I am already using the 3 channels...last one is for an external bec...so this leaves me short on the fan plug for my mm. Can I power the fan on top of the mm through any other slot on the rx?
Or am I SOL. Too much of a chicken to find out..would rather ask than ruin a $ 100- rx
NO!!! The sensor ports are 3.3v IIRC use a Y splitter - the traxxas ones are cheap
I read that Chris after posting. So I can split the AX ch which has the bec in it or should I do another ch.
This is why I double check first!
Doesn't really matter - The + and - on all the other channels are linked...
Figured as much...thanks again
