Originally Posted by aznnboiy
thats sit?i thought it would be like 50mph like the erevo brushless
it all depends on the gear ratios and what motor mount you get
with the tekno mount you have to use a clutch so you will be limited to a max gearing of 17/36
i have close ratio gears in mine (i track race, not bash)
i run 5 cell lipo
with revo responce tires (5.1 in tall)
you end up with a top speed of 41mph.............but, the clutch will slip,the slipper will slip,your batteries wont hold 18.5v under load and many other things factor into lowering your top speed and you end up running alittle over 35mph
a revo conversion can be pushed to almost 100mph with the castle 2200 motor,6cell lipo, e-revo transmission and foam tires............. just depends on what you $ want to spend
