All, Rejoice for NEW LiPos!
MetalMan
MetalMan's Avatar
All, Rejoice for NEW LiPos! - 12.07.2005, 09:38 PM
http://www.hobbypeople.net/mfr/implse01.asp
http://www.toddsmodels.com/Lithium/i...ndhyperion.htm
These new Impulse cells are rather good. All (or many) are the same as the new Hyperion cells, but are less expensive. Believe it or not, the Impulse 2100mah cells are most likely the same thing as the TP Prolite 2100mah cells :eek:, but at a fraction of the cost! This means that you can get TP performance and low weight for much less:
http://www.tppacks.com/products.asp?cat=13
The difference in size and weight comes from the pack construction; the Hyperion and Impulse have foam padding, and the TP don't. Internal construction may also be different. It is just incredible that you can get a TP 3s 2100mah (15C) pack for $10 from Hobby People (the Impulse pack), or $12 less from the other website!
David, you gotta start taking advantage of that employee discount :cool:.
Serum
Serum's Avatar
12.08.2005, 02:34 AM
they are rather cheap, but their preformance isn't all that?
Nick
COOKIES!
Nick's Avatar
12.08.2005, 05:38 AM
Yeh, if I was ever to go Lipo it would be for the performance not costs. :)
~ Nick.
MetalMan
MetalMan's Avatar
12.08.2005, 10:00 AM
The great thing is that some of the Impulse cells come from the same factory as TP. If you want TP performance, but don't like the cost, then you want these!
I wonder if the 3200mah 20C uses the same cells as the Kokam 3200mah...
Serum
Serum's Avatar
12.08.2005, 11:44 AM
I don't know an other cell, that does 3200mAh and is 20C, i am pretty sure it is the Kokam, Metalman.
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
12.08.2005, 04:01 PM
eehh, the mah is kinda low. could put them in parrelel or something
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
MetalMan
MetalMan's Avatar
12.08.2005, 07:58 PM
Yes, it is, and parallel would be the way to go. But for the price, you can't go wrong (compared to TP). Also see here for inexpensive 10C Lipos:
http://www.his-hershobbies.com/page/page/978479.htm They will be making parallel packs, as well as higher series packs. 11.1v and 21amps continuous for $37 isn't bad! To make a 6s pack for a 9XL, you would only have 4 packs in total, so only $148, including taps! That's for 42amps continuous and 22.2v (nominal)! Only downside is that their form isn't the greatest.
tyrewq
12.09.2005, 09:06 PM
wow that's a pretty good deal
dabid
12.13.2005, 10:56 PM
So wait, which ones do I have to buy now? I saw this one (the 2s1p 7.4v one) or this one (the 3s1p 11.1v), those would be the best right? How would these compare to the 3s2p 8000mah pack here? I had planned on getting two of the 11.1v 8000 packs from that guy, with taps added for $12 per pack, and liked the idea of the extra long runtime.
But now I just saw that page for the loose cells, now I'm all confused.....:D
MetalMan
MetalMan's Avatar
12.14.2005, 09:50 AM
Get those TrueRC packs for sure! I was pointing out that there is another Lipo battery that you could use your employee discount with ;).
dabid
12.15.2005, 09:29 PM
Yeah, I'm pretty set on those packs, but if only I could figure out a charger............better wake that thread up again......;)
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
03.03.2006, 07:20 PM
Is that true lipo site for real???? A 4s 4000mah pack for only $85 dollars? That would nearly half the price of competitors
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Serum
Serum's Avatar
03.04.2006, 03:42 AM
25A continues isn't enough Re~mix.
