looking for 5mm 48p pinion
phildogg
phildogg's Avatar
looking for 5mm 48p pinion - 12.29.2009, 07:38 PM
anyone know where to get these? I ordered one from dan @ kershaw but its going to be awhile he is waiting on the gears to come in. I'd like if someone else would make them also. (hint hint mike) If anyone knows where else lmk please.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
12.29.2009, 10:22 PM
Just get a negative bore reducer.
Seriously, I have no idea.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
12.29.2009, 10:26 PM
A 32-pitch spur might be a better idea.
phildogg
phildogg's Avatar
12.29.2009, 11:42 PM
yeah it would be if I could find one that could fit with a decent ratio. smallest spur I've found is 56t and that a good bit bigger than the stock 72t 48p ,so that would mean I'd have to run a really small pinion. not what I'm looking for.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
skellyo
skellyo's Avatar
12.29.2009, 11:59 PM
Try rc4wd.com...they have a few.
http://www.rc4wdstore.com/2/index.php?cPath=29
J57ltr
12.30.2009, 12:07 AM
What size pinion are you running now?
phildogg
phildogg's Avatar
12.30.2009, 09:58 AM
right now I'm running a 30t pinion.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
J57ltr
12.30.2009, 10:17 AM
Then run a 23 tooth pinion that gives you a 2.435:1 where the the 72/30 gives you an even 2.4:1.
Jeff
phildogg
phildogg's Avatar
12.30.2009, 10:28 AM
That would be great if it would fit. I suppose you mean a 32p. problem is they are too big to get any decent ratio. There just isn't enough adjustment.
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
whitrzac
Can't catch this...
whitrzac's Avatar
12.30.2009, 11:04 AM
what car?
12.30.2009, 11:09 AM
Probably his TC4 (in his sig)...
phildogg
phildogg's Avatar
12.30.2009, 11:35 AM
yeah its for the tc4, thought I had that in the thread but didn't.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Unsullied_Spy
Unsullied_Spy's Avatar
12.30.2009, 02:02 PM
Dan @ Keshaw Designs and SDP-Si.com are the only places I know of that sell them. I had a 21 or 22 tooth brass pinion that was 5mm bore but the grub screw rounded out and I had to cut the gear off. If I still have the gear you can have it and use some loctite 604 to stick it to your shaft.
