Brake Setting when using mechanical brakes? -
03.09.2010, 10:56 PM
I'm running a Mamba Max in my Ve8. I'm planning on using the mechanical brakes.
I was wondering what to set the ESC Brakes to so that they don't come on at all?
Seems the lowest number I can enter for "brakes" is 10%. Will that be sufficient so the motor doesn't do any braking? If not, what setting should I use and set?
+1 for TeknoRC. If you decide to use the Y-Harness on the throttle channel, just make sure your linkages are adjusted so the brake does not engage when applying throttle.
If you do mixing on your transmitter rather than a Y-harness, you can further reduce the chance for brake by turning the brake EPA down to 0% for the brake side after you program the endpoints on your ESC.
